The Best DTS Amp below £300
Discussion in 'AV Receivers & Amplifiers' started by steroid, Aug 5, 2001.
  1. steroid
    steroid
    What are your suggestions for a DTS Amplifier below £300? I plan to buy one and dont know which reviews to trust. I was hoping you guys could help.<br />Thanks
  2. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    check out the Yamaha RXV520RDS at <a href="http://www.richersounds.co.uk" target="_blank">www.richersounds.co.uk</a> it's about £255, I dont work for them.
    Tim
  3. Fx
    Fx
    Get yourself a demo of Yamaha DSP-AX620. I expect it has rock solid performance. My friend has a DSP-A5. The AX620 is a replcement for that with about 20w extra power. From hearing the DSP-A5, I expect it to impress for it's price.
  4. steroid
    steroid
    Thanks Guys, But is there any amp with Dolby EX for the price I am looking at or maybe a little more?
  5. Guest
    Ding ding at £300 all passengers please alight here, the next train heading for DD EX/DTS ES will be the £600 (ish) Denon 3801/2.
  6. Guest
    Due to changing rolling stock this train will also be stopping at the £500 (ish) Sony 1070 however we would advise passengers to remain seated until we reach Denon.
  7. steroid
    steroid
    hehe. I get the picture. Do you think it is worth the extra cost? or just DTS should do for now?
  8. Guest
    Wholly dependant on what size your room is - if it's small then ex/es has a much lesser impact than a large room, can you live with another 2 speakers?. That said i wouldn't be without it and would have 20 speakers if required. I would spend more if you can.
  9. Fx
    Fx
    Also, try to check out Kenwood KRF-V7030, I dont know if it is the best for below 300, my friend picked one up for junk and it sounds good for the price.
  10. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The Denon AVR 3802 will indeed do dts-es and DD EX, but don't expect to ever reach the price of £600, unless there are non-profit making hifi organisations, sine the MRP has gone up to £849.99.
    The cheapest Denon dts-es option is the AVR 2802, which has 6 channels of amplification on board, it's MRP is £649.99.
  11. Fx
    Fx
    Thanx Retro. Since you own a AV business and stuff do you think the Yamaha Dsp Ax620 is a wise choice at its price or can you suggest something better
  12. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    How about the Marantz SR5200 - DTS, DTS ES 6.1, pro logic II 6 x 90 watts £329 at <a href="http://www.empiredirect.co.uk" target="_blank">www.empiredirect.co.uk</a> or save for the Denon 3802 £630 at <a href="http://www.hifijunkies.co.uk" target="_blank">www.hifijunkies.co.uk</a>
  13. 11aa11aa
    11aa11aa
    Can I be really uncool and say Sony940. Since I bought it I've been really happy with it. Was £500 when I bought it so it's a real bargin now.
  14. siymann
    siymann
    or if u want EX sound as well, get an old Prologic amp, and feed that the rear speakers signal from a 5.1 amp. connect up your 3 rear speakers to the pro-logic amp's front 3 speakers setup, BANG! u now have 6.1 Surround Sound <img src="wink.gif" border="0">
    diagram:
    <br /> [​IMG]
    [ 17-08-2001: Message edited by: siymann ]</p>
  15. Fx
    Fx
    Wont that give me the sound going to the front centre the sound I recieve in the rear centre?
    it may sound stupid but I haven't a clue about AV stuff.
  16. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  17. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    It probably doesn't sound as good because matrix decoders have come a long way since DPL was invented. The principle for EX decoding is the same, but is much better now.
