the best connections to use
Discussion in 'AV Receivers & Amplifiers' started by rjperry25, Nov 6, 2005.
  1. rjperry25
    rjperry25
    I recently bought the following kit
    Pioneer VSX-AX5iS AV receiver
    DV-668AV DVD player
    PDP-434HDE PLasma screen
    Sky+
    It's all connected up and is running fine. What I would like to know is this.
    Q: At present the DVD is connected to the tuner via conponents and the sounds goes to the reciever via digital coaxial. Could I not use just a HDMI connection and have less cables and better quality picture and also use a optical toslink instead? The sky+ is using scart plus a toslink.
    Also what is the iLink connections used for. Is that batter than HDMI and optical?
    Last but not least HDTV? Is the Plasma I bought HDTV ready?????
    A bewildered beginner!
  2. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Cant help on anything much but i thik iLink is for connecting up a camcorder
  3. avjon
    avjon
    Dec 31, 2004
    121
    Lincoln
    +12
    Hi rjperry,
    In reply to your use of i-link, it is only an audio link, not video, while your HDMI output is used for video and audio. As your 668 does not have an i-link socket you would be best connecting the 668 and the AX5 by coaxial digital cable to transmit DVD audio, quality phono cable to transmit analgue CD audio, and 3 phono cables to transmit SACD/DVD-audio multichannel surround sound. You would then connect your 668 via HDMI to your HDMI eqipped display. I know this is a lot of cables but unless you upgrade to an 868/989 DVD you will not be able to i-link your AX5 to your DVD player.
    You would also connect your SKY+ box via RGB scart to your plasma, and by optical digital cable to your AX5.
    I hope that this does not confuse you too much!
    Jon.
