The best connections for Panasonic DMR-E85 with Panny IDTV
Discussion in 'Blu-ray & DVD Players & Recorders' started by PanicLord, Jan 16, 2005.
  1. PanicLord
    PanicLord
    After reading these forums and many hours experimenting, I think I have probably found the best settings for my equipment. As everyone's advice was so useful, I thought I would post back what I did.
    Equipment:
    TV: Panasonic TX-28DTX1C IDTV 100hz model.
    On this TV, only AV1 has RGB in. There is no RGB out. Q-Link only works properly from AV2.
    DVD/HDD: Panasonic DMR-E85H.
    My connections are as follows:
    AV1 to AV1 with scart.
    AV2 to AV2 with scart.
    Use AV1 for playback, allowing you to watch DVD/HDD stuff in RGB.
    Use AV2 for recording.
    On the DVD I set up AV2 input as "Video", "Decoder", "Ext Link 2". That means all I have to do to record is set the EPG on the TV, and leave the DVD in Ext Link recording standby mode.
    This seems to work well, although Q-Link functions don't seem to work at all now. However, at least I can playback in RGB!! Let me know what you thinnk...
  2. PanicLord
    PanicLord
    Actually, have since found out that the recording does not stop at the end!!
