The best Chip for Xbox ?..
Discussion in 'Xbox Forums' started by jerkyboy, Sep 2, 2004.
  1. jerkyboy
    jerkyboy
    I want to Modify my Xbox purley so I can enable the Hi Def progressive scan modes.
    Could anyone tell me which upgrade to go for and from who.
    Thanks.
  2. mitch
    mitch
    Sep 6, 2003
    5,390
    +638
  3. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Also check out the forums over at www.xbox-scene.com for reviews/user opinions on the various brands and models. I would tend not to look any further than Xecuter - they consistently seem to be producing the best chips, and have decent support in place for those "oops" moments ;)
    Just my 2p worth :)
    K.
  4. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Just bought the xecuter 2.3 lite from premodded.net (including console), haven't tried the hi-def yet as I am waiting for a hi-def cable from lik-sang.
    Azzo
  5. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    If you get an Xecuter (which i've just ordered), get it from MrModChips he and baldbouncer are the only authorised dealers fior the chips in the uk, and mrmodchips seem to offer cheaper postage than baldbouncer.
    Rich
  6. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,176
    +1,189
    Bit late, but I used www.premodded.com after seeing recommendations on here, and they were very good (note their prices don't include VAT, but do include postage). Premodded add loads of utilities for you, and if you upgrade your hard drive (which I'd recommend - putting your own games on the HD saves having to swap disks, and it's also usefull for copying dvds) they'll copy all your old saves to the new drive. And I'd recommend the Xenium or SmartXX chips (you don't have to manually switch the mod off for going live with these).
