The best 28" 50hz TV
Discussion in 'General TV Discussions Forum' started by Squall Strife, Jan 22, 2003.
  1. Squall Strife
    Squall Strife
    Hi guys, i need your help ^^
    I'd like to know which is the best 28" 50hz 16:9 TV.
    I've seen the Sony 28LS35 and it seems quite good, he has a good price too. So i'd like to know if there are any other tv (may be better ^^ ) for the same price ;)
  2. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    You could check out the above model - basic features but a spot on picture.
    Just ordered mine for another room from John Lewis. Price matched at £460 - free delivery and five year warranty.
    Tim
  3. moogy20
    moogy20
    I've just been lookin at gettin that TV. Where did you get it at that price from please?
  4. Squall Strife
    Squall Strife
    Thanx themmings ;) I've heard 'bout that panny, everyone say its a good tv, but i'm worried 'cause someone say that it has some video problems :confused: is that true? Have you got some probs with it?
    Anyway, you think that its a good tv to use with Playstation 2?
    Thanks again ;)
  5. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    moogy20: purchased from John lewis, price matched against Sound and Vision.
    Squall Striffe: Some say certain models can have geometery problems, but to be honest most (not all) true flat widescreen have some kind of geometery issue - some worse than others.
    For out right picture quality, it's right at the top IMO for a £460 price tag.
    Tim
  6. lentini
    lentini
    Jun 28, 2002
    3,578
    Dog Eater
    +455
    Panasonic TAU tubes are not truely flat. they are curved a bit and they just slap a piece of glass in front of them.
  7. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Yep, but they ain't far off. If you look at most screens there aren't many that are totally totally flat.
    ...Unless you shell out for a Plasma - which is what I'm doing:p
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I really fancy one of these but they are expensive!!!TX28DTS3 Great spec and the 32" is even sweeterTX32DTS3 But I havent seen either at any webtailers, Only at Local Panny dealer.
  9. lentini
    lentini
    Jun 28, 2002
    3,578
    Dog Eater
    +455
    The trinitron tube in my LS60 is
  10. Nello
    Nello
    PRC Direct sell these two DTS TV's, well they have them on their website at least.
    h**p://www.prcdirect.co.uk/PRC/PRC.storefront - go to the Digital TV section under Televisions.
    32" = £1150
    28" = £850
    Dunno if PRC can be used as a price match.........
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Have a look at the Sony KV32DX40 the internal DTTV tuner is good
  12. rmsdev
    rmsdev
    Check out the philips 28DW6557 iDTV
    50 HZ
    Great picture and sound
    2 RGB scart (manual says it has one...)
