The AE700 really hurts
Discussion in 'Projectors, Screens & Video Processors' started by danadama, Jan 23, 2005.
  1. danadama
    danadama
    Just bought my first projector a panasonic AE700
    pictures look excellent
    I have watched about 8 hours and have pain in my eyes after watching and the next morning, they really ache.
    My eyesight has always been perfect, never needed specs until now, not had any problems with cinema or TV.
    currently projecting onto a white wall 4.5m away with varying
    picture sizes and ambient light levels
    Has anyone had the same experience and what did you do
    do I need to sell my equipment and give up with projectors?
    Please help
    Dan
  2. junkster443
    junkster443
    buy a brighter projector 1200-1500 Lumens
    Sony HS50 might be worth a try for you
    and make sure to buy a projection screen as well i do not reccomend wall as a screen
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,615
    2
    In a secret location with Jennifer Lawrence
    +9,325
    Firstly, I would get an eye test.
    Did you watch 8 hours in one go, or is this cumulative?
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,152
    +3,022
    I got a bit of a headache when I watched my projector for the first time. I took it, as just getting used to the big image size.
    I wouldn't recommend 8 hours in one go (if you did it like that).
  5. Yaka
    Yaka
    Dec 20, 2000
    1,740
    2
    63
    +130
    ive been considering geting a projector (mianly the HS50) my self. but i have been warned if i am gona use it alot i may get eye strain. as i have no tv at the moment i will be using it more than most. anyone got any advice?
  6. Jules
    Jules
    Oct 11, 2000
    5,575
    134
    +1,036
    Its probably just a sinus thing.
    I actuallly find viewing on the projector much easier on the eye.
    If you think about it, when watching a TV screen your eyes are focusing on a high level light source over a smaller area. There is no 'average' light level for your eyes to adjust to.
    However, watching a huge projected image fills your field of vision and your eyes can adjust to the average light level.
    Of course, 8 hours continuous focus at a single fixed object is not good for your eyes whatever your looking at. You need to focus on objects at varying distances once in a while.
    My eyes get tired after a long film on my LCD projector, but on a DLP projector I'm going cross-eyed after 20 minutes.
