the $64 million Qustion : Plasma vs LCD?
Discussion in 'Plasma TVs Forum' started by mk85, Oct 20, 2005.
  1. mk85
    mk85
    here's the deal. i'm looking to buy a flat tv but i'm not sure which way to turn. i've gone to comet and curry's and have had a look at some plasma's and LCD's but can't decide which one is better. the salesman just tell you what you want to hear!
    i've got £1500 to spend. i would like it to be around 42inch and it will be mounted on the wall.mostly i'l be watching sky and occasionally DVD's. i would just like some info on the best models/makes out there for this price. and is it better to buy from high street stores or the internet.
    The plasma i was thinking of was samsung - PS42S5S - is it any good.
    any info will be appreciated
    Thanks,
  2. johndon
    johndon
    Feb 3, 2002
    1,996
    63
    +128
    Try a search on the forum for "Plasma V LCD" - this has been discussed loads of times.
    John
  3. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    How comes this question seems to get asked every couple of days. Come on new guys put some effort in first.
  4. rudy
    rudy
    Jan 2, 2005
    499
    If you are ok with 37", look also at Sharps new aquos p50 37" lcd, a good pic and very good value at 1200 (look on kelkoo) or spend the extra and get a panny pv500 37" plasma.
  5. Mindvox
    Mindvox
    For £1399, and if 100% HD Ready is not optimal (but HD Compatible is acceptable), then look no further than the LG 42PR3VX, 42" Plasma.
    I just took delivery of one on Monday (from Dixons) and it's absolutely phenominal and features HDMI, Component, VGA, and RGB.
  6. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    Similar requirements to me. If you have a sound source (hifi?) you could go the panel only route (like me!) and apparently get slightly better PQ - I am very pleased with mine. :smashin:
    I think you will find that at 42" plasmas are probably better PQ.
    The search function is your friend ;)
  7. rudy
    rudy
    Jan 2, 2005
    499
    Some internet stores give you the run around. No names mentioned as I don't have first hand experience. If its a case of 150 quid then stick to a store
  8. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    I would usually go with recommended ones only. But I have rarely had problems anyway.
  9. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Or for fifty quid more a Panasonic D8
    [c'mon - someone had to start the Panasonic bandwagon again!!!]
