The £2000 question
Discussion in 'Projectors, Screens & Video Processors' started by mystex, Sep 18, 2001.
  1. mystex
    mystex
    Sep 15, 2001
    108
    Brighton
    I've got 2 grand to spend and I've narrowed it down to 2 projectors. The Toshiba MT3, which I've seen for £1999, and the Infocus LP-340b(£1974). The infocus sounds fab (1300 ANSI lumens), but has anyone had a demo of it? Reviews are very good also. I have had a demo of the Sim2 200HT which blew me away-I didn't suffer from the rainbow effect though I wasn't looking for it so hopefully I'm compatible with DLP!
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    dont forget to try the sanyo.....
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    1300ANSI is a huge amount of light to throw at a home cinema screen. More light doesn't equal better pictures, so don't just buy the brightest projector for your money unless it is just for business presentations.
    Home Cinema requires subtlety. Contrast and colour accuracy is more important than absolute brightness.
    The Toshiba MT3 is plenty bright enough (850 ANSI). Infact, some folk think that even this is too bright and so use grey (rather than white) projection screens to tone down the power.
    Have a look at the dedicated home cinema projectors from Sanyo and Toshiba. They're designed with features and picture quality enhancements that home theatre enthusiasts find important once the wow factor of a big screen has worn off.
    Regards
  4. mystex
    mystex
    Sep 15, 2001
    108
    Brighton
    Thanks alot for the info-will go back to the drawing board!
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
