That plasma that lights up the room
Discussion in 'Plasma TVs' started by Stampax, Jun 28, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,314
    Northampton
    +52
    A while ago there was a plasma that heavily advertised - with the key feature being that it lights up the wall it is on so is more comfortable to view in the dark. I think it might have been Philips? Was this any good - never seem to see it mentioned on here - not worth considering?
  2. Anthall
    Anthall
    Oct 27, 2004
    219
    Kettering
    +4
    I believe it was a Philips, but i thought it was an LCD with something
    called Ambi-light?
    Im sure you will get a full and correct answer within the next 10 mins.
  3. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    It is indeed the Philips 9986 32" and 37" LCD tvs. I believe Phillips new plasma range will also have ambilight.
  4. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    I've seen a Philips with ambilight on a wall display at JL, although because of the bright showroom lighting, you get no idea of the effect it might have in a darkened room. I must say the picture was nothing special and the set itself looked bulky to me.. A few folk on the "get you plasma out for the lads" have installed their own backlighting.
  5. Teccy Toker
    Teccy Toker
    Dec 16, 2004
    68
    Yup....FOCUS DIY do a range of LED backlights (to uplight planters and decking etc) in strips.....One transformer, controller and 2 strips for £29.99 and a addon pack of 2 strips for £19.99....it werks great stuck behind your plasma.
    TT
  6. Duckman
    Duckman
    It's also found in the Philips 42PF9966 Plasma model..... :)
    Looks really nice...and it actually changes color depending on what you are watching. :rolleyes:
  7. Stampax
    Stampax
    May 6, 2005
    1,314
    Northampton
    +52
    So is the plasma model any good - ie in terms of PQ etc? Anyone got?
  8. shugg
    shugg
    I've got the 42pf9966 and yes i like it a lot as a one-box solution. Most folk on this forum want separates and therefore go for a panny + scaler,etc and their pq will be better, but as with all separates yoy need expert help in finding the right combination. I already had a LOT of hi-fi gear and do not have the space i my flat for more. The deciding factor for the phillips was motion judder - All the others had it to one degree or another, except the phillips. A word of caution, some of the others have bought scalers for the phillips to not much effect, search the forum and you should find these posts.
    Use the forum as a guide then use your own eyes to chose the one for you, NEVER EVER order solely on anyone's reccomendation.
    shugg :smashin:
  9. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    I dont think they have been released yet.
  10. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    42pf9966 has def been released and is readily available (even Curry's have them!)
    This made it into my top 3 choices (the others being the Pioneer 435 and the Panasonic PV500 (which I eventually bought) The philps was my wifes No 1 choice as she preferred the design (and the funky lighting) The only thing I didn't like was the resolution 1024 x 1024I (ie interlaced) I wasn't keen on a HD screen that needed interlacing to bring it up to the required HD resolution
    just my 2c
