Thanks to Rasczak
Discussion in 'Blu-ray & DVD Players & Recorders' started by SIP, Aug 12, 2003.
  1. SIP
    SIP
    Aug 10, 2003
    132
    NORTH YORKS COAST
    +3
    just to say thanks for the link to RGB Direct.
    I took your advice, and placed an order with them last night for the E50. I have advised my retailer this morning, that I no longer require the one thats due on Friday.
    Please could you let me know the place were you get your -r from for 50p each, as pointed out in one of your other postings. Also, any brands to avoid - as I said before my main concern is archiving, so a decent disc is needed.
    Thanks again for your help
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Have a look at the DVD-Rs on this site:
    http://www.blankdiscshop.co.uk/
    They do a media test package so you might want to try that to get a feel of which disks you prefer and which work best with your recorder (The E50 has effectively three different drives in different models based on the Matsush*ta D321a or D321c or Panasonic D321b which means some media works better in some drives than others). They have White Label disks available (in a spindle of 25) for £0.49 (inc VAT).
    Personally I normally use:
    http://www.digitalpromo.co.uk/
    However their site is broken at the moment.
    Also try here:
    http://www.blankcdr.co.uk/acatalog/CDR_Supplies_Direct_DVD_Blank_Media_20.html
    They have DVD-Rs at £0.49 (plus VAT) but I have used this service and they aren't very fast. Some people rave about them though.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    If your going to archive I would spend that little bit more on a disk - around £1.50-£2 each - just to guarantee it will last the duration. I do strongly suggest trying the trial pack though.
