Thanks Jeff
Discussion in 'AV Receivers & Amplifiers' started by John Watts, Feb 11, 2001.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Thanks Jeff your help was very kind and usefull i have checked out the celestionC5's you told me about and they seen fine,and not too big. Could you do me another favour and suggest a good price and perhaps a place to shop for them,(do you think the internet is ok)? thanks again your knowledge is most kind,John.
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I bought mine from AudioT for £269 (10% discount), they have a shop in Basingstoke where I live. Ideally you should buy from an authorised dealer, you can find a list on Celestions web site. You could try the internet but you may struggle to find a site that sells them.
    By the way I have the Celestion bi-pole rears and small direct radiation (mono-poles) speakers as back rears (placed higher up on the wall) and the combination works very well.
