Thanks for help - just finished setting up my first projector!
Discussion in 'Projectors, Screens & Video Processors' started by Snoopstah, Jan 8, 2005.
  1. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Hi Guys,
    Just like to say thanks for all the help you've given me - I haven't posted much, but the information and discussions on here have been invaluable in both choosing and setting up my first projector.
    Obviously, after upgrading from a 15 year old Sony TV (albeit a top-of-the-range one), anything was going to be better, but I can honestly say that it's unbelievably fantastic! I'm speechless every time I watch things on it, even if they're from a low-quality source!
    For reference, I'm using a Panasonic AE700 with a home-made 66 inch screen. Haven't seen any VB, haven't looked! I'm sure the experts could do all sorts to set it up better (I haven't even touched the picture settings on it yet), but to me, it looks pretty damn amazing.
    Couple of pics:
    [​IMG]
    [​IMG]
    [​IMG]
    Thanks again!
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    just thought I'd stick the same screenshot taken off of my Infocus 4805 for a bit of fun !
  3. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Good pausing skills!
    Your image looks 'warmer' than mine - probably my Xbox's fault, I've heard that they tend to output everything with a green tinge...
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    still, not bad at all for an Xbox connected probably via a basic composite connection is it? And not a hint of VB that I can see.
    It would seem the Panny AE700 has received a little too much bad press of late and it's about time someone addressed the balance.
    Welcome to the projector community my friend !
  5. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    RGB Scart. I've not seen any VB at all, but equally, I'm not keen to go looking for it on purpose! If I don't notice it during normal viewing, it might as well not exist, as far as I'm concerned :)
    I actually got it as it was one of very few PJs that would do the screen size I required from the throw distance I had to have, but I never expected it to be as good as it is - especially with the bad press it seems to get!
    Think I'll have to finally cave and get a proper DVD player with component output, though :)
  6. thfccambs
    thfccambs
    Jul 17, 2002
    19,148
    White Hart Lane
    +5,255
    Snoop are you going to use the ae700 as your main TV?If you don't want to spend loads on a dvd player have a look at the pioneer 575.Excellent picture using Progress scan and component.
    Anyway screen looks great and so much better than the Infocus 4805. :laugh:
  7. thfccambs
    thfccambs
    Jul 17, 2002
    19,148
    White Hart Lane
    +5,255
    Also how big is your screen?
  8. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Looks like a good unit, does SACD and DVD-A too.
    Will be using the AE700 as my main TV. Still got my old TV behind the screen (which lifts right down), but having watched TV on the PJ in the daytime today and with the 2x100W ceiling lights on, it does a fine job. Obviously you lose a lot of contrast, but for casual watching it's fine, even on low-lamp mode.
    Cheers :)
  9. thfccambs
    thfccambs
    Jul 17, 2002
    19,148
    White Hart Lane
    +5,255
    So how bigs your screen?
  10. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    65 inch, which helps with the brightness in daytime. Viewing distance is only just over 2 metres (small living room), so despite sounding like a small screen, it still looks huge :)
  11. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    They do, without a doubt. A friend of mine mentioned he was going to stop using his Xbox for DVDs after comparing it back to back with a cheapo DVD player because of the green tint. I thought he was probably imagining it, so checked mine (never used if for DVD playback before) and sure enough it's there.
  12. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Hunts1uk, on what are you basing your opinion of the screenshot on the ae700 being so much better than the 4805? From my observation, the ae700 lacks the contrast and the colour rendition of the 4805 ( at least in these two images). As Snoopstah says, it's probably due to the Xbox feed, but the only advantage the AE700 has over the 4805 is in it's resolution which is not an issue in these images. The 4805 has better contrast and because of the Xbox, has better colours in these images...........Not that I am biased of course !!
    ( No offence Snoopstah !)
  13. thfccambs
    thfccambs
    Jul 17, 2002
    19,148
    White Hart Lane
    +5,255
    I was joking m8,calm down it's only a projector. :thumbsup:
  14. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    :boring: :boring: :boring: :boring: :rtfm:
  15. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Not at all! I thought it was a bit controversial when he said it! :)
    For reference, the 4805 was the only other projector in my price range that would do the required image size given the throw distance. The reasons I chose the AE700 above it were (in no particular order):
    1. DLP rainbows - don't affect me, but I was worried that visitors might feel ill.
    2. Brightness - as I knew I wanted this as my main TV, the 1000 lumens of the Panny was better than the 750 lumens of the Infocus.
    3. Cost - while they cost around the same here, I fundamentally object to Infocus's pricing scheme on this PJ - it retails for around 1200 quid over here, but can be bought for $1299 in the US. Smacks a bit of 'rip-off britain' to me.
    4. Resolution - having seen HDTV in the states, even though there is currently no OTA programming for it, I really wanted something that could handle it eventually.
    A 3-chip DLP would have been a no-brainer, if I could have afforded it!
  16. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    I know, I know... Sorry guys, didn't mean to sound so 'anal' !!!!
    I really like the AE700, just couldn't afford one at the time !
    :oops: :offtopic:
  17. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Have to say that your set up looks superb.
    Well done.
    Welcome to the FP club. That screen set up is superb and some what ingenious. Congratulations. All the best and simply enjoy after your hard efforts.
    One last thing, do buy a dedicted DVD deck with progressive scan is this will improve the image further. As an EX Panasonic owner I can validate this. Hope this helps.
    Captain Benefit.
  18. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Thanks! Will definitely be on the lookout for a good DVD player at a nice price :)
  19. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Keep an eye on the hardware sales forum here. Bargain central sometimes.
    Cheers,
    Cap.
  20. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    Most people with PJ's go down the HTPC route to watch DVDs. Have you a PC at home?
  21. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    A few ;)
    Plan on doing that, but for the setup I'd like for a dedicated HTPC I'm looking at around 500 quid, so a cheap but decent DVD player would be a nice interim step while I save up a bit!
    [​IMG]
  22. martian1
    martian1
    Dec 30, 2001
    2,257
    83
    Sunderland
    +325
    I like both screenshots either would do me..no need to fuss :rolleyes: both lucky guys :smashin:
  23. stu mcc
    stu mcc
    Nov 13, 2004
    588
    +23
    martian
    yep, 'nuff said mate
  24. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    i dont think you can compare projectors based on digi camera pics at all. The camera and decor has much more of an effect than the quality of the projector, on the output picture, and hence decision!
    Just for interest, here is a post I just made with a similar picture from Shrek 2.
    Well I have had a go taking pictures, unfortunately now that I have put them on my pc i can see that the shutter speed was far too slow, i will have to try freeze frame next time as my current camera doesnt support a faster shutter speed. Also my camera is awful in the dark so I might need to get closer or turn up the brightness next time i take pictures (ill try that soon). Anyway ill attach them for you to have a look at.
    http://www.photobox.co.uk/album/1127264 (the awful pixellation is from the camera in dark) (the Shrek 2 picture comes from DVDx2 on the xbox)
    By the way, these are the settings I made with a DVE disk (I think it is NTSC if that makes any difference). Started from Normal settings and then:
    +4 Contrast
    -8 Brightness
    -2 Colour
    0 Tint
    +3 Sharpness
    Low Lamp mode
    As for flicker adjustment, I was wrong. I settled on the final values of Blue 26, Red 27, Green 26 and have no noticable VB what so ever. That is in the desk setup mode.
