Thanks Dr John
MarkHudds
Just wanted to comment on how good the service is from Dr John Sim (symanski) ...
Sent a cheque for a RGB to Component convertor on Thursday and it arrived by special delivery on Saturday morning!
The other thing that struck me was the build quality... far better than anything similar I've had from other accessories suppliers (mention no names)...
So thanks John, and by the way it's an excellent box that does exactly what it says on the tin!
Jon Weaver
Mark,
Have you used it yet? How 'sharp' is the picture??
For example, say you went to a menu screen of your Set Top Box or DVD player, how clear are the edges of the text?
I am still swaying between VGA and Component and have to make up my mind in the next few days.
MarkHudds
I can't tell the difference between the converted picture and a straight RGB connection! Text is excellent - no blurs.
I use my VGA connection for a PC, therefore I had no choice but to get the Component box. Also means I can switch Sky via my component switching amplifier!
Totally recommended (not cheap, but it's the best you're going to get!)
symanski
Thanks Mark!
I just build the units the way I'd expect them to be built - and have always set myself a high standard. Yes, some work is done outside, but the companies I choose also serve Linn, Motorola, and Rolls Royce to name a few. Other accessory suppliers are obsessed by price, while I'm looking for quality. And everything is done in the UK I'm proud to say!
All the best,
Dr John Sim.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
