th50pz70b or th50px70b which to buy
Discussion in 'Plasma TVs Forum' started by markkat, Jan 15, 2008.
  1. markkat
    markkat
    Jan 4, 2008
    2
    hi new to forums ,would like to know which is better and why ,also where is best and cheapest to buy from.
    thanks:hiya:
  2. rupees_al
    rupees_al
    Mar 12, 2007
    202
    28
    +31
    i'm sure you'll get a bunch of standard answers to this one...
    search... thats right the internet is your friend...
    the best will depend on what you want and how much you wanna spend
    a th50px70b-ped can be had for £1028.01 HD ready
    and a th50pz70 can be had for £1267.91 Full HD
    and a th-50pz700-ped can be had for £1643.91 (newer/higher spec) Full HD
    only you can really choose which is best for you and for what your gonna use it for.
    where to buy depends on if you wanna internet shop or walk into a highstreet supplier so you have easier comeback if anything goes wrong.
    i would personally always buy the most expensive i could afford on the most suitable set at that time. stuff will always be replaced and be cheaper you just have to decide how far into the future you wanna protect yourself.
    and set the thing up correctly for what you want to.
    eg i was at a customers house the other day when after i commented on his 50" panasonic he complained that his skyHD didn't look as good as he thought it should. he was watching it thru the VCR scart socket - on PAL... nice. and it cost him 4k 15mths ago. and he'd had HD for 8mths lol...
  3. google
    google
    Dec 31, 2006
    2,990
    +1,623
    If you are intending buying either of these you need to say which feeds you will be using with it, Sky HD etc as this will help forum members give you advice on which might be better suited to you.
    Both these plasmas are very good but I bought the PZ70 as I intended to use a lot of HD feeds to it.
    Scott
  4. markkat
    markkat
    Jan 4, 2008
    2
    will be using sky hd and xbox 360 and a wii , where can these be brought online for under £1300
    cheers
    :thumbsup:
