TH50PH10 or PX70 purple snake problem PH9
Discussion in 'Plasma TVs Forum' started by Jensemann, Sep 9, 2007.
Thread Status:
Not open for further replies.
  1. Jensemann
    Jensemann
    Hi, I am in contact with panasonic complaining of the bad contrast and poor black level compared to my old TH42PHW6 (G6 Panel).
    No I recognized a little magenta problem (like the purple snake problem)
    My question is, if Panasonic is willing to change the complete Plasma would the PH10 be the better choice or the PX70 if you just use it as Sat TV and HD-DVD? I don't like the PX70 design, that was the reason why I took the PH9 and normallly the Pof. Panels have a better processing inside. (are both without any magenta problems?)
  2. CHFels
    CHFels
    Feb 20, 2007
    495
    +42
    Why did you just start a new thread when the other one, nearly the same title, in which you are the last poster, is still active and on page 1???
    Moderator, move the prev. post to the other thread!!
    CHFels
  3. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    I noticed that last night & decided it was a different question (i.e. should I get a PH10 or PX70?) so left it.
  4. Jensemann
    Jensemann
    You can close the thread... although I didn't want to mix the to questions... but it's ok, if you close it!
    I thought maybe this is worth a discussion what are the pros and cons comparing those to models
Thread Status:
