D
Dr EdAV
Put your mince pies on these prices for the TH50PF9UK..
http://www.bhphotovideo.com/bnh/con...ATH50PF9UK&is=REG&Q=&O=productlist&sku=473620
$4.5K = £2.28K
will need to factor in the £50 for a step up converter on the power front, but the rest of the panel is UK compatible (PAL 60/60Hz).
With 1 pound to every 2 dollars, it is tempting! Probably will not survive the flight back... unless you can pay extra for special handling or cabin space ?! Anyone know if you can do this? Also, are plane holds pressurised... I'm guessing that the gas filled cells of plasma will leak if put in a low pressure environment... or does it only matter if the TV is run at a low pressure environment ?
Ted
$4.5K = £2.28K
Ted
