Quantcast
th50 st30 screen reflection
cejsmith
i was wondering if any one could tell whats the 50" st30 like with screen reflection. my living room has picture window at the end and i get some relections from my current 7404 philips.
if its bad any ideas of another set around the same price and size
thanks
vickster
There are people who have returned or decided against the ST30 due to reflections - this is something that you'll get with all plasmas and many glossy screened LCDs
Unfortunately, the ST30 is such a good price at the moment, you won't easily find anything else that big
I believe the LG LCDs/LED-LCDs may have matt screens and you'll maybe get a 47" for £700 (probably won't outperform the ST30). The 46" Samsungs will all be shiny (and won't be 3D for £700) and the Sonys too expensive too in a 46"
Maybe look at something like this LG 47LW540U | 47 inch 3D LED TV 1080p HD Ready Freeview | Richer Sounds
Only plasmas come in 50"-51" screens. LCDs in 46-47 and then 55 (which will be £1300+)
Might be time for thicker curtains :D
