TH42PX80B or TH42PX80BA
Discussion in 'Plasma TVs Forum' started by matboyslim, Jan 31, 2009.
  1. matboyslim
    matboyslim
    Jan 31, 2009
    2
    My new TV arrived this morning. I ordered a TH42PX80B (cost £570) When it arrived the label on the box says TH42PX80BA. Have I been sent the wrong model?
    Many thanks
  2. mistymoo
    mistymoo
    Nov 23, 2008
    73
    torquay
    +6
    pretty sure ba means its got the updated software :thumbsup:
  3. Perrioli
    Perrioli
    Jul 26, 2004
    95
    11
    Belfast
    Where'd you get it from?
  4. mr pea
    mr pea
    Oct 27, 2008
    19
    3
    B mean UK version
    A means its the newer version of that model with extra hdmi port and higher contrast ratio.
    You have been sent the correct set, most suppliers advertise as PX80B but the panasonic model is PX80BA.
    Do not worry it is correct, enjoy!!
  5. matboyslim
    matboyslim
    Jan 31, 2009
    2
  6. audiphile76
    audiphile76
    Jan 29, 2008
    2,595
    Espoo, Finland
    +307
    There is nothing wrong with the model. Its just that this model has the front covering in plastic instead of glass plus some software upgrades. Other than that its just the same. No worries, enjoy your new babe.
  7. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    Talk of extra HDMI connections and plastic versus glass screen are all wrong.
    The 'BA' version has been updated over the 'B' version with updated hardware, not software, and this will be to eliminate a design weakness in the original 'B' version.
    The PX70 was similarly updated last year from 'B' to 'BA' after the infamous green line issue. The panel/pcb was redesigned to eliminate the problem.
  8. mr pea
    mr pea
    Oct 27, 2008
    19
    3
  9. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
  10. audiphile76
    audiphile76
    Jan 29, 2008
    2,595
    Espoo, Finland
    +307
    I think you are confusing with 42PX8B. PX8 has 2 HDMIs while the 42PX80B still had 3 HDMIs.
  11. mohsin_uk
    mohsin_uk
    Nov 11, 2008
    287
    London
    +6
    Wow that sites got the th-37px80 for under £420!
    thats got to be the cheapest I have seen it by far
  12. mohsin_uk
    mohsin_uk
    Nov 11, 2008
    287
    London
    +6
    My mistake its the px8 and not the px80
