TH42PX600 and JL pricematch...help!.
Discussion in 'Plasma TVs Forum' started by potatoman, Aug 28, 2006.
  1. potatoman
    potatoman
    Looking to buy this but need advice on the pricematch.
    i have used the search function but there is so many pages im struggling to take in all the info:confused:
    never owned a plasma so need the 5 yr warranty,but too expensive to buy seperately.
    i know that ed are selling for about £1680 inc post(any retail stores cheaper?),but i live near gatwick,so no local ed or jl.(nearest is kingston or bluewater)
    can i get a price from any jl store or only local to ed?
    is it loads of hassle?
    will jl pricematch even though its not in stock(in stock at ed)?
    can i order from a northern store but collect from my nearest?
    i tried ringing jl but no answer,so hoped to get help from here from anyone who had the same problems.
    thanks
  2. Meeten
    Meeten
    Jul 4, 2006
    110
    Scotland
    +3
    the comparison will have to be matched with a place THAT HAS IT IN STOCK.
    ED will be matched with JL - distance doesn't really matter.
    I suggest that you contact Oxford St, BlueWater, Kingston (app they are a pain in the a$$) and the people that I found easiest - Bristol. My sister (in Surrey) got a PM from them (Bristol & ED) and got it delivered no probs.
    Best bet is to contact a few, and then show the letter / ref to the nearest branch ..... result.
    Good luck :smashin:
