TH42PWD7 or TH42PWD6BX
Discussion in 'Plasma TVs' started by johndevine, Aug 10, 2005.
  1. johndevine
    johndevine
    I am about to buy a plasma (eventually) which is the better picture quality between these two Panasonics? Both are in Richer Sounds for 999
    JD
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    picture is the same
    on the 6 you can input RGBHV and componant into the onboard VGA socket.
    on the 7 you can only input RGBHV into the onboard VGA socket.
    B = official british product (so the 7 might be a grey import)
  3. johndevine
    johndevine
    If i get the triple input card, can i do component then?
    JD
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    I would go for the 6 series personally, being able to input component on the vga is excellent.
    Also I am not sure what the score is with fluctuating brightness levels but I was reading just yesterday on the avsforum that people with PW7s are still noticing it.
  5. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    I sencond the 6 I had both and 6 was better.
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    I had the 6 as I wanted componant input on the VGA
    Looks like the concensus is for the 6.
  7. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    i have a pw7 and i havent noticed the fluctuations in contrast on mine and i notice faults on stuff pretty quickly.i have never seen a pw6 so i cant say wether or not it is better but there was some consensus about the pw6 being a much dearer screen on release compared to the pw7 so maybe it had better components but i have to say i was a plasma sceptic but now i have one i have to say im more than happy with it over my sony ls60 crt.
  8. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    The PW4/5 are still regarded as some of the best plasmas ever made too.
    I suppose when the glass was costing £2k each then the manufacturers could justify putting expensive power supplies etc. in there, now the glass is only costing a few hundred pounds you have to try and save money elswhere too?
  9. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    the 6 was £3500 when released the 5 was £4500. there isnt much time between the 6 and 7 but the retail cost difference was huge.
  10. peterakastorm
    peterakastorm
    You can't out component trough the built in VGA port? Why is that?
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    on the 7 they disabled it, so they could sell more component boards I guess.
  12. peterakastorm
    peterakastorm
    That's just rotten... well, I'm gonna buy the 7 anyway... it's much cheaper, isn't it?
  13. johndevine
    johndevine
    BNot from richer sounds....same price
    JD
  14. peterakastorm
    peterakastorm
    Yeah, that's right... But I'll have to order from Germany, as shipping from the UK will add 250£ to the price :S
    But is the 6 series superior in PQ too? Or is that the same? And will the 6 series do HDTV?
