TH42PWD6BX help needed
Discussion in 'Plasma TVs Forum' started by Macleanrd, Dec 12, 2004.
  1. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Hi All
    Im going to be buying TH42PWD6BX pany in a few days and need some advise before i part with my money.
    I have sky plus and also a pany home theatre system, sky is connected through a scart 21pin to av1 on my present tv, my home theatre is through scart as well and goes to av2 on my tele. I only have a scart connection on the home theatre and as far as i can tell on sky too. Can i have this set up on the pany pw6? Do I need anything extra? or is there a better way?
    Please help
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +445
    I am curious how well this works. As I pointed out in another post, if you connect via VGA, the Panasonic provides no colour level controls (just contrast, brightness and sharpness). With no colour control, I have seen other devices such as a Daewoo tuner box which was much too saturated.
    Additionally not all the widescreen modes are accessible on the VGA input, such as Just and Cinema.
