TH42PWD6 Connections
Discussion in 'Plasma TVs Forum' started by intrinsic777, Jul 8, 2004.
  1. intrinsic777
    intrinsic777
    Feb 19, 2004
    12
    Could anyone tell me the best way to connect the following to the above. The Panny has three slots, two at the moment taken up with scart boards, the other spare. I need to connect a DVD player (RGB), Digibox (RGB), VCR, PS2 and Xbox. Slot three will not accept a composite or a scart board so how can I connect all these units up whilst able to keep RGB on the Digibox and DVD.
    Help!!!
    Andy
  2. EpsomJames
    EpsomJames
    Jul 2, 2004
    176
    +8
    Probably many ways to connect them all up, but you're going need some additional kit. Does your DVD have component out? If not how about this:
    Quintro switcher (link below) plugged into SCART1 on PWD6
    Digibox RGB, PS2 and XBOX plugged into Quintro
    VCR plugged into Digibox non-RGB (assuming Digibox has 2 SCART, only 1 of which is RGB) otherwise also plugged into Quintro
    DVD plugged into SCART2 on PWD6
    http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?BT945
    p.s. I'm new to all this stuff, so may not be best advice out there.
