TH42PW7 scart setup
Discussion in 'Plasma TVs Forum' started by dino2020, Mar 1, 2005.
  1. dino2020
    dino2020
    Need some advice before I take the plunge :)
    I am thinking of getting the Panasonic TH42PW7 from Digital point
    £1,294.90 inc VAT With SCART Board(TY42TM6T) Inc Delivery
    Here is my setup now
    I have a Yamaha amp with AV switching
    tv out mode is SVideo
    Sky + out to amp with Svideo
    Dvd to amp with Svideo
    Xbox to amp with Svideo
    Dvd Recorder to amp with Svideo
    so the way I see it is feed the plasma scart with the svideo to scart lead from the amp, I do this at the moment no problems at all , just wondering if the scart panel wont accept s-video on the panny?
    Also any better deals than this at the moment??
    Dino
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Better deals, probably not as long as you need no support from your dealer. They are cheap, don't expect them to run a technical help line. Your proposed setup will work, and look reasonable. Likely you will want to upgrade the video connection in the future, but you will be up and running with a big flat thing, so go for it.
