TH42PW7 Problems.
Discussion in 'Plasma TVs Forum' started by rizingdamp, Dec 24, 2004.
  1. rizingdamp
    rizingdamp
    Ok just connected a TH42PW7 to a Pioneer DBR-TF100 freeview box via scart to the scart on the plamsa(input2). I have follwed to the letter the relevent instructions with regard input siganl settings but have come up against a problem.
    According to the manual having pressed the set-up button on the plasmas remote I am shown the set up screen. So far so good but whereas the manual shows the first option of....component/RGB in selct.....and being able to toggle between the two then I just have a blank box. ie I can`t even choose RGB.
    However I do get a picture, quite surprising a good one having read some of the reviews with regard plasmas and digital artefacts.
    Anyway any help with regard the above would be much appreciated.
    Thanks guys,
    Andy.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    scart can only accept RGB/Composite on PW7... Component is an option for VGA/RGBHV boards and means nowt to scart board..Which auto detects RGB+Composite sync..........
  3. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    This is normal.
    I have exactly the same set up.
    Ken
