TH42PW6 & Denon DVD-A11
Discussion in 'Plasma TVs Forum' started by Thatsnotmynaim, Jul 7, 2004.
  1. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,746
    137
    Middle Earth
    +629
    Has anyone used these two bits of kit together using the DVI-D connector? If so can you get 720p? Also is this the best setting to use?
  2. jrpavel
    jrpavel
    Jan 25, 2004
    178
    16
    I have tried the two units together, but find the picture almost unwatchable (posterization of darker areas). I get a much better result through component. Trying to go for 720p is not much of an advantage as the screen only has a resolution of 480.
