TH42PF11 set up problems
Jimwa
I have a very strange problem with this screen paired with a Denon AVR1909, Sony BDPS350 and Humax Foxsat HD box. HDMI from both sources to 1909 then HDMI out to the DVI input on screen - the problem is that i can't get any picture or audio from the Foxsat when routing through the Denon just a black screen. The Blu Ray is fine and both are ok when connected directly to the screen.
If i disconnect the HDMI lead from the monitor output on the amp the sound from the Foxsat back comes on - it seems like the screen, Foxsat and 1909 won't sync together.
Any help or ideas gratefully received!
YellowSphere
You need to connect the Foxsat by optical for 5.1 from channels that use it anyway, so just assign that to the video input and you should be sorted.
