TH42PE50-S Video or Scart?
Discussion in 'Plasma TVs Forum' started by dognuts, May 15, 2005.
  1. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Ive been using my TH42PE50 for a week now and im not totally happy with the picture quality.(T.V. channels in particular)Im mainly concerned with DVD however.
    My DVD player supports S Video and Scart.At the moment im connected via scart but would S Video be better?
    Also,when i switch on my DVD player the channel automatically switches over to show the DVD,but in the corner of the screen it does not state RGB.Im fairly sure that its an RGB lead.Am i doing something wrong?
    Thanks.
  2. MrNPG
    MrNPG
    Apr 13, 2005
    777
    Poole, Dorset
    +63
    You will need to make sure that you have set your DVD player to output an RGB signal and that you are using one of the RGB compatiable SCART sockets on the TV. I have the same TV as you and two out of the three SCART sockets are RGB compatiable (AV1 and AV3)
  3. Peabo
    Peabo
    if you can afford it, I'd say go for a new DVD player that supports a component connection. What connection are you using for TV channels?
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,864
    Galactica C.I.C.
    +279
    OK,
    well Component or RGB through a scart lead are the better ways. Then Svideo through scart or the svideo socket at the front.
    Like has already been said, check if your player can out put RGB first.
  5. david1966
    david1966
    Hi just set my 42pe50 up this weekend, I initialy was not impressed with the TV picture, changed coax for quality item and retuned. What a difference!
    Pictures are now sharp and there are no fuzzies on any channels.
    I got the ES10 recorder dvd free with mine and the picture through component is absolutely stunning.
    Like the majority of replies in the forums, the answer is you get out what you put in, quality in = quality out.
    The picture on this set is amazing when set up right.
    Dave
  6. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Right then,
    Ive set DVD to RGB output and i dont think its made any difference,although to be honest im finding that its only with older or poor quality DVD's that the picture quality is lacking anyway.(im maybe being picky-not sure.)
    As for the TV connection-im not really sure i know what you mean by "what connections am i using for my TV channels".As far as i know i can only use a coax from my rooftop aerial.Is there another way?I was connected through my VCR but ive now plugged the coax straight into the plasma but it hasnt made any difference.
    By the way,if i do decide to go for a new DVD,can anyone recommend one.Im not really bothered about a recorder,just a player.Also,any recommendations on component cables.
    Thanks.
  7. knobbs
    knobbs
    hi ive got the pe37 after seeing both in shop, they were both connected same and the 37 was a much better pic than the 42.
    ive had it running since sat and pic quality is amazing, even on the footy.
  8. Peabo
    Peabo
    Make sure the Scart cable is connected to an RGB compatible socket - not all the scart sockets on your TV are RGB compatible, check the manual. Also, make sure the cable itself is a fully-wired RGB scart cable, it might be a standard composite one.
    Coax aerial is the ultimate, bottom of the barrel piece of crap cable. Yes, your TV channels will look rubbish through this. Get a freeview box and connect that using whatever outputs it allows (should have at least scart RGB).
    I have a pioneer DV-575A DVD player and it's really good! Won't cost you more than £100 either. It has component output so get a nice component cable with it.
  9. knobbs
    knobbs
    hi -scart 1 and 3 are both rgb.
  10. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Ive got the DVD in RGB now.I already knew that AV1 and AV3 were the RGB sockets but didnt have the DVD player set to RGB output.
    im still not sure what you mean Peabo when you say coax is crap and get a freeview box.the plasma has a freeview decoder in it so i dont understand what you mean.
    at the moment i have my coax straight into the plasma from the roof aerial and some channels look fine whilst others are pretty dire.(ITV2,Sky sports news,and generally all of the freeview channels).
    Thanks all.
  11. david1966
    david1966
    Was the TV picture good on your old set?
    Like I said in my previous post, i replaced the supplied coax lead with a half decent one from maplins and retuned the set and the picture went from fuzzy crap to absolutely brilliant.
    If the coax comes straight in and doesnt go to a wall mounted plate have you tried a signal booster?
    Dave
  12. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Yeah i thought about a signal booster but wanst sure how or if it would work with the freeview decoder-ill try that.
    The picture on my old CRT was ok-nothing stunning but then i wasnt using a freeview box.I suppose another thing is that im in a bungalow and the reception will probably be weaker than a normal house anyway.
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    a new aerial is probably the best idea (or at least get an aerial expert out to take a look and some measurements)
  14. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    By the way Peabo is the pioneer DV-575A DVD multi region out of the box.ive looked at it from a few different places and some state multi region and others dont :confused:
