TH42PE50 (cab) - space for Yamaha RXV1500?
Discussion in 'Plasma TVs Forum' started by Goofy, May 25, 2005.
  1. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    I am getting a Panny TH42PE50 with floorstand (cabinet) which I want to combine with a Yamaha RXV1500. I know that the shelves are adjustable, but would a RXV1500 fit on the bottom shelf, with the Panasonic DM10 on the centre shelf, with a centre speaker on the topshelf I don't mind if it partially obscures the PE50's speaker - which I am not planning to use).
    I am soon going on holiday to Austria (by car), where I am planning to pick up a Yammy1500 for £360. Would of course be a bit useless, if it turns out not to fit on to the shelves.
    Any advice from an existing Viera owner using this combination, would be greatly appreciated.
  2. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,310
    63
    +128
    The bottom shelf (highest) of the PE50 cabinet stand is 151mm (same for both 37 and 42 ver), the height of your RXV1500 is 171mm so would guess it won't fit. As far as i know the height is not adjustable. The newer pv500 cabinet stand lower shelf has two settings 143mm or 203mm, but i guess that doesn't help you :(
