TH42PE30B connection issue
Discussion in 'Plasma TVs' started by steveho, May 15, 2004.
  1. steveho
    steveho
    Apr 21, 2004
    164
    +3
    Just planning ahead for when i get my TH42PE30B,when mating it with say a DMR-85 dvd recorder using the component connection how do i get the audio signal across?
    Do i use 2xphono plugs (analogue audio out)on the dvd to the scart connection as stated below
    Audio Input (for Component Video)
    Co-use with AV4 21-pin In
    so i need :- 2x phono to scart lead?
    ps .i don't have a surround system .
    steve
  2. Deron
    Deron
    Sep 11, 2002
    365
    +12
    I may be wrong, but from what I vaguely remember the pe30 has 2 audio ins...
    Straightfoward audio connection.
  3. steveho
    steveho
    Apr 21, 2004
    164
    +3
    The audio for component must go into av4 (scart) according to instructions ,my question is how do i get audio out of the dvd player when using the component
    steve
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think you use both 3 RCA phonos for Component Video and a 21 pin scart for Audio (both cables!) then set E85 to component out and PE30 to Component in on AV4 and away you go. (I think)
  5. steveho
    steveho
    Apr 21, 2004
    164
    +3
    hornydragon,
    do you think i would use the scart on the dvd therefore using a scart to scart lead or the two phono outputs therefore using a 2x phono to scart lead?
    steve
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think it is a standard scart mate 21pin to 21pin try it with a cheapie and see if it works.
  7. bobbles
    bobbles
    i don't know but i would be pretty sure you would use YUV component cables. Then use 2xphono lead for sound. However, I would image most people would use the digital out to an amp for surround sound.
  8. bvs
    bvs
    I've recently got the 37" version and page 46 of the manual shows how to connect Componenet Input terminals: Componenet cable from DVD to AV4C sockets on tv and also scart - scart from DVD to TV (AV4) for sound signal input. Hope that helps.
  9. Deron
    Deron
    Sep 11, 2002
    365
    +12
    So to get stereo sound from a component input you have would have to sacrifice a scart?
    Is that right?
    Seems a bit daft.
  10. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Yep that is right and it is daft!!!! The amount of times i've cursed over the thing not just having a separate input altogether for component... :mad:
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Having spent the last 3 days sorting out PE30 problems, stand issues mainly, i can only express my surprise at the number of poeople buying the PE30! the PA20 was bad enough but PE30 is even better/WORSE!
  12. steveho
    steveho
    Apr 21, 2004
    164
    +3
    Thanks BVS ,
    component cables and full scart required then,av4 i think is rgb equipped so that seems a bit of a waste also,
    so to watch a dvd on the plasma i select the component input on the pe30 and the sound comes automatically i presume
    steve
  13. bobbles
    bobbles
    i am suprised you have spent so much on a plasma and nothing on a surround sound system ???
    what problems are you having HD? you can get the stand for 420 now
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Just getting them looking good I am getting less and less keen on integrated tuner Plasmas. The Floor stand is not my favourite and it looks rather odd on the table top stand! Not had to wall mount one yet but i guess i will eventually!
