TH42PE30 Image to wide
Discussion in 'Plasma TVs Forum' started by KarlRobinson, Mar 13, 2005.
  1. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    Are there any hidden menus on the TH42PE30, I find on the widescreen setting the picture is slightly too wide.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    there is thread that tells you how to correct the overscan via service menu you will need a test pattern I suggest a copy of DVE PAL or AVIA NTSC see the DVD disks power buy thread and have a search..........
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    forgot to say that if you are going to go into the service menu, wright every thing down first before you change anything. You can do a lot of damage in there if you are not carefull.
