Th42pa50,th42pd50,th42pwd7,th42pd25
Discussion in 'Plasma TVs' started by themachine, Jul 20, 2005.
  1. themachine
    themachine
    Hello everybody....
    i would like to ask u some questions cause i m a noob......
    1>i live in europe......i am searching for the panasonic plasma th42pd50 but it seems that i can only find the th42pa50 model here(i leave in greece).Is it the same model?are there any differences and if yes which model is better?
    2>I found the th42pa50 model for about 2390 euros with the table stand.Is it a good price?
    3>Anyone knows if the th42pd50 model is as good as the th42pwd7 or the th42pd25 model(i have read that these models are the best)
    4>is there ant difference between th42pa50 and th42pa50u model?\
    sorry for any mistakes i ve made but i am a total noob......
    and one last question
    5>is the th42pa50 a good choice? or i should go for a different model or brand?
    thank u
  2. gnikolaidis
    gnikolaidis
    I live also in Greece. The model your are interested at is the new TH-42PA50E which is the new 8th generation plasma TV from Panasonic, the same model that is distributed in Germany, France and Italy.
    The TH-42PA50E retails in Greece for euro 2,250 with the stand at Kotsovolos. If you are adventurus you can find it for euro 1,800 if you order from internet in Germany. I just purchased my TH-37PA50E (the same model as the TH-42PA50E with slightly smaller screen) for a total cost of euro 1,670 from www.technikdirekt.de
    The are reliable, and they accept credit cards. I had to wait for 30 days for delivery, but I believe that a savings of euro 400 was worth the effort).
    If you have more questions send me an email.
