TH42 Viera PC connection options
Discussion in 'Desktop & Laptop Computers Forum' started by Dade, Oct 22, 2004.
  1. Dade
    Dade
    I’ve just got my Panny TH42PE30 Viera and I’m really pleased with it.
    My only problem is the fact that the VGA socket is on the front of the unit. I knew this before I bought the screen but underestimated how much it would annoy me now that I want to connect my PC.
    What I’m wondering is if there is an alternative way for me to connect my PC to the VIERA. I’ve seen some info on the web about connecting the VGA card to one of the RGB Enabled scarts with a home made cable - is this a good idea? Does anyone actually make this cable commercially?
    I’ve also seen a Radeon graphics card that has a component RGB output. Only trouble being that its PCI express only.
    Can anyone offer me any advice on this?
    Thanks.
  2. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
  3. Dade
    Dade
    How sharp a picture can I expect using this method?
  4. Mr.K
    Mr.K
    Did you try the ATI adaptor? and if so does it work? I also have one of these TV's and I'm also having the same problem. Didn't think the VGA socket would be a problem until I decided to get a media centre & then you start wondering why you didn't get a TV with a rear mounted socket :oops:
  5. Skunkpipe
    Skunkpipe
    I use one with my TH42PA20
    The good point : Picture quality close to VGA - much better than s-Video.
    The bad point : you can't use higher resolution than the displays native res - so given my (and your panny isn't HDTV ready then 640x480 max).
    As there are no UK suppliers of these I've imported a batch from the US - they should be with-in the week.
  6. Mr.K
    Mr.K
    How much are they?
  7. Skunkpipe
    Skunkpipe
  8. rab4169
    rab4169
    Dec 12, 2004
    533
    seriously considering this tv, if i hook up my ati 9700 to this can i still play games at their native resolution or will i need to play doom3 at 800 x 400
  9. Skunkpipe
    Skunkpipe
    you'll need to play doom3 at the screens native res.
    TBH there is no advantage in playing it at anything above the screens native resolution, if anything, because it's a reletively low res you'll be able to turn up all the effects...
    I have 3 left in stock ATM if anyone is interested
  10. Rambles
    Rambles
    Jul 14, 2004
    9,556
    137
    UK
    +1,767
    If you are using a VGA or DVI connection you can play the game at any resolution you want.
  11. Skunkpipe
    Skunkpipe
    indeed you can - put is there any point in using higher than the native res?
  12. Rambles
    Rambles
    Jul 14, 2004
    9,556
    137
    UK
    +1,767
    Well on a low resolution the icons and text are massive and they take up a lot of the screen.
  13. rab4169
    rab4169
    Dec 12, 2004
    533
    the point is the vieras now do not have a vga or dvi input and would need to use component to connect pc , just to see what resolution i can use on component compared to vga
  14. Skunkpipe
    Skunkpipe
    Component allows you to use upto the native resolution of your screen (852x480)
  15. Skunkpipe
    Skunkpipe
    Not an issue with any games I've played TBH.
  16. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,481
    Cornwall
    +122
    2 penth worth : the vierra is basically the same screen as mine (i think) and IMO higher res's 1064x600/1280x768 look much nicer than native. I play games like Halo, Sims 2, Sim City 4 (lots of interfaces on the last 2).
  17. Mr.K
    Mr.K
    Thanks I managed to get a ATI DVI/Component adaptor direct from the states (as I'm still waiting for the media centre to be delivered the week turnaround on the adaptor wasn't an issue ) it only cost £13 incl p.p.
