TH37PX70 - PC Connections
adubsounds
Hey Guys
I Bought the PX70 on saturday..............completly over the moon with it.......an absolutly fantastic television
I do however have a little problem i could do with some of your fantastic advice on.
As this television is in my bedroom i want to use it as the primary screen for my PC as well....
Yesterday i used the D-Sub connection to connect to my PC and it worked fine, although the image wasnt very clear..............
Later on in the day i planned to connect it up properly, play with the settings and the resolutions to get the best picture, but when i connect the cable into the D-Sub port i got no picture.............so i restarted the PC......got the windows loading screen on the television and then blank screen.......
Can anybody please help me get the PC picture back
Or
Recommend a better way of connecting my PC to this fantastic television
Adam
bu5ter
sounds like you are ausing a resolution taht is too high i think the native res of the 37" is 1024x768 so try that first but it defiantely has them listed in the manual if you wanna check
adubsounds
i will do mate.....................
is using the D Sub the best way to connect my PC up or is there a way i can use one of the HDMI sockets?
bu5ter
well i would suggest that yeah vga is fine and using the pixel settings in media player even when using a 1024x768 res you can view video in the right ratio. I think it needs to be on 1.330 to be correct.
if you are going to be using a hd-dvd or blu ray drive then might be worth investing in an hdmi graphics card and running a native 720p output. This way you will not have any hdcp isues later on.
B
balearic
Does anybody know if the Radeon X1650 can support HD?
I am going to hook up my Panny 42PZ70 via the DVI-I out on the card into the HDMI input of the TV, but don't have the TV yet, get it on Saturday. I have bought a cable with the above connections from ebuyer to enable me to do this.
If anybody knows that this won't work, I'd appreciate it as I can probably still cancel the cable. Cheers.
