Th37pw7bx - Th37pw7b Whats The Difference If Any?
Discussion in 'Plasma TVs' started by apgibbo, Apr 26, 2005.
  1. apgibbo
    apgibbo
    Folks, had my plasma for about 6 weeks now have used DVE - pal on my HTPC and I am over the moon.
    When I bought it it was advertised as a PW7B but I received a PW7BX.
    Is there any differen?
    The manual leads me to believe it will accept 720p HDTV signals (accept and display rather than being HDTV compliant) Is this so?
    Regards,
    Adrian
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    i think x means no speakers (or something like that) either way it's the norm and mine was the same. It is not HDTV compliant.
  3. apgibbo
    apgibbo
    Thanks for clearing things up Mep :thumbsup:
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    no worries...enjoy!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    IT will accept 720p and 1080i at both 50 and 60Hz but only over analogue RGBHV/Component not DVi/HDMI
  6. apgibbo
    apgibbo
    Hornydragon - does that mean it's not HDTV but it won't baulk if you feed it an HDTV signal?.
    Also if I feed an HDTV signal through the vga port on my HTPC will it just downscale it and will I notice any differece in quality.
    I ask because windows ATI drivers let me output at 720p and 1080p - I tried them and they worked fine - even though I had no signal to put through it.
    Adrian
    P.S. it's all academc for now but I bet blue ray drives and HD dvds will be quite cheap (eventually) on the PC
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    it is not "HD ready" as per the EICTA guidlines but you can watch loads of res signals on it, 720p should look the best........
  8. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Go on, treat yourself, you know you wanna.
