Th37pw7 Picture With Sky
Discussion in 'Plasma TVs Forum' started by Baron Von Doom, May 29, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    Picture is excellent via dvd but sky not that good.
    Is there any way to improve the picture with sky. Its going via panasonic dvd recorder then media box with monster scarts.
    Also get some lip sync probs with dvd player (toshiba sd530e) is there anything that can be done to cure this
  2. zest
    zest
    Jan 24, 2005
    147
    16
    kenilworth warwickshire
    try a js rgb>vga converter loads of threads on this issue :thumbsup: i also believe the media box reduces pq :rolleyes:
  3. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Lip sync probs from Sky wouldn't be unusual but surprised that you have it from the DVD. How is the DVD player connected to the panel?
  4. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    monster s video to scart lead. have component cable as well not sure if it does it with this as well. some films are worse than others.
    also vga input is being used by pc
  5. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    I suspect that the dreaded "tuner box" strikes again. Lots of previous threads on this.
  6. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    I have heard that their not that good. What would be the best way to connect everything up. was thinking scart box with dvd and sky into dvd rec then into plasma with component input board.
    Wasnt that impressed with component and media box though. could this be media box or lead(thor component cable 3m) picture seemed to look better with rgb scart or s video
  7. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Thor component cable is good, media box isn't and the conversion in the DVD recorder isn't brilliant. JS Tech converter is much better but more dosh.
  8. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    where do i get these converters. what would be the best boards to get for plasma for picture quality
  9. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Many of us sponsors of the forum sell the converters. The VGA converter gives a much improved Sky picture though you lose colour saturation control (some think this is a problem, in practice it rarely is, in my view) BUT you already have a PC going into the VGA port so would need another VGA board if you aren't going to be swapping cables. The more expensive, but more convenient option is the RGB to component converter plus a component board for the plasma.
  10. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    is there a cheap way to convert the pc to a different signal. would a vga to scart cable work or would the signal have to be changed?
    this would then leave the vga port free for sky/dvd etc.
  11. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Not a PC expert but I think you are suggesting sending the PC output via that tuner box again! I can only imagine that it will do the same nasties to the PC output as it does to video. Flog it and use the money to get the right bits.
  12. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    i meant use the vga port on screen for sky/dvd dvd rec then and put pc into scart or something then get rid of media box. do people buy these boxes
  13. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Amazingly some folk have managed to sell them for goodish money on ebay!
    Once the tuner box is gone which scart are you thinking about?
  14. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    i have a jvc scart box think its 4 scarts to 1. every thing into this. then scart box into dvd revcorder then dvd recorder into plasma. but dont know what board to use yet
