TH37PW7 all set up, what settings to use for best PQ?
Discussion in 'Plasma TVs' started by RockSteddie, Apr 11, 2005.
  1. RockSteddie
    RockSteddie
    Mar 26, 2005
    1,110
    +127
    Hi All
    Got my brand new 37PW7 set-up an running today along with a Dennon DHT500SD all in one system. All I can say is I'm very chuffed so far, the PQ is better than I expected :thumbsup:
    Thanks to all the forum regulars for giving great advice!
    So..... what would be the best settings to use while the screen is running in, contrast , brightnes etc?
    I want to give it the best possible start in life :)
    Any help would be much appreciated.
    Omino
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    best bet is to avoid the dynamic setting, also avoid fixed images for too long, keep brightness and contrast reasonably low for 1st 200 hours.....but other than that its just a case of what looks best to you.....because your room, the screens position, sources, etc will all impact on pq other peoples settings aren't rally that useful. many folk consider isf calibration after 200 hours to get the most from their beasties!
  3. lisag
    lisag
    Jul 14, 2004
    5,696
    Essex
    +336
    I used the DVE disc after 200 hours to do some callibration.... it is not easy to follow :eek: but gives you a good idea of what to aim for.
    Then after that I have just tweaked a few settings according to taste, I actually seem to find everything too red, but in the advanced user menu there is some options to reduce the red, which can be 'normalised' if all goes pear shaped!
    lisa
  4. RockSteddie
    RockSteddie
    Mar 26, 2005
    1,110
    +127
    Thanks for the advice guys... I'll have a fiddle with the contrast and brightness when I get home from work tonight !
    Lisag, where to you get hold of the DVE Disc ?
  5. lisag
    lisag
    Jul 14, 2004
    5,696
    Essex
    +336
    Here!
