Th37pv500b In Stock
Discussion in 'Plasma TVs Forum' started by The Cleaner, May 26, 2005.
  1. The Cleaner
    The Cleaner
    Apr 13, 2005
    19
    Just in case any of you guys are waiting to get your hands on the TH37PV500B. I've just ordered one from Powerhouse and they have 10 in stock. They also offered me delivery for Tuesday :)
  2. alliwant
    alliwant
    how much did u pay?
  3. kevin harrison
    kevin harrison
    Panasonic in Derby have them also, just ordered mine, £2040 with wall bracket, 3 yr warrenty and free Panasonic DMRE S10.
  4. The Cleaner
    The Cleaner
    Apr 13, 2005
    19
    I paid £2199 which included the pedastal stand and free delivery.
  5. alliwant
    alliwant
    what made you go for the 37"? the logic tells me that the 37 would suit my needs and pocket but keep being drawn to the 42....arghh
  6. The Cleaner
    The Cleaner
    Apr 13, 2005
    19
    I nearly went for the 42" but on balance I decided on the 37" based on price and the distance I will be from the screen. I think even with a hi def signal the 42" would have been a little too big.
  7. kevin harrison
    kevin harrison
    Living room size, distance from screen...
