TH37PE50 display input signal
Discussion in 'Plasma TVs Forum' started by Brido, Jul 19, 2005.
  1. Brido
    Brido
    Aug 12, 2004
    36
    Hi guys,
    This might sound like a silly question but I just cant find it!
    Is there a button I can press on the remote or something and it will show me what signal is being input to the TV..ie RGB, 720P etc etc
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I've got a 42PV500 and if you press the i button on the remote it will display,which av channel,aspect ratio and display resolution (480p,720p etc) currently being used.Should do the same thing on PE50.
