TH37PE50 - Component Connections
Discussion in 'Plasma TVs Forum' started by ashleybrown, Oct 27, 2005.
  1. ashleybrown
    ashleybrown
    Sep 26, 2004
    35
    11
    Leicester
    I'm the proud owner of a new 37" PE50 plasma. I'm really happy with it but have a question. My current DVD player (Sony NS900V) has component outputs (which I'm using) but does not output progressive scan. Would it be a big improvement to change my DVD player to one that does output progressive scan or stick with what I have.
    If so, which player would you suggest.
    Ash. :)
  2. mal60908
    mal60908
    I would stick with your DVD player fow now, until HD-DVD arrives.
  3. chrisw
    chrisw
    May 20, 2004
    2,421
    83
    Maidenhead
    +263
    Apparently if you're feeding the PE50 an interlaced signal, the TV itself will do the progressive scan bit...
  4. ashleybrown
    ashleybrown
    Sep 26, 2004
    35
    11
    Leicester
    Cool, so I'm already watching the dvd using progressive scan, although the tv is actually doing this for me.
    Does this apply to anything pluged in? ie my sky+ box via RGB or just my component inputs?
  5. longy
    longy
    Jul 7, 2005
    362
    Canterbury/kent
    +21
    u will get a better picture using a progressive scan dvd player :thumbsup:
  6. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    I sold my NS900, and bought a Pioneer 575 from Richers for £99. The quality on my 37PE50 is better than the NS900 IMO :)
  7. ashleybrown
    ashleybrown
    Sep 26, 2004
    35
    11
    Leicester
    Hmm ok.
    But will it match my sony for audio, I do listen to Cd's using this dvd player also.
    If I'm going to swap my dvd player then I'll probably change the amp so they look good.
    What would you suggest?
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    this is not necessarily true, as has been pointed out to you before. the plasma will always display everything in progressive, as the panel is progressive. if the plasma can do a better job at de-interlacing than the player, interlaced will look better.
  9. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    AFAIK, the Panasonic on-board deinterlacer does not have film mode - not a good thing if you're asking it to deinterlace 24 fps originated material.
  10. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    Ahh, you never mentioned the the CD's before. That I can't tell you, as I never used mine for CD replay. The only way to know is to try them for yourself.
  11. ashleybrown
    ashleybrown
    Sep 26, 2004
    35
    11
    Leicester
    Thanks guys,
    I'll probably wait a while and save up for an Arcam DV78 player. That does progressive scan and is an excellent DVD player.
    Ash.
