TH-50PV30B advice
Discussion in 'Plasma TVs Forum' started by Mr Eddy, Jun 19, 2005.
  1. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    Can anyone give me some advice on the quality of this screen, or point me to some reviews.
    Also can it receive a high def signal via some sort of connection box?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Analogue HD only via component (1080i signals only) for 720p needs to be front panel VGA for RGBHV
    In short a real pain in the rear and a bit of a lemon when it comes to a 50"a 50PHW7 is far better the newer pannies PV500 and PHW8 also much better buys as is the Fujitsu P50XHA40US unless your being offere it for under £3k i would walk away and even at £3k it could be a very costly mistake probably panasonics worst plasma of the last 5 years..........
  3. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    Oh well, worth a try. Noticed it was now hitting the 2999 mark with a cabinet stand.
