Th-50phw7
Discussion in 'Plasma TVs Forum' started by sapkan, Nov 9, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    Is this screen coming out soon? any details on connections
    want to connect an hdmi player and an rgb scart to it :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well surely the company you bought it from discussed your cabling requirements with you and the fact that the HDMI board is not yet available and that the Panny scart board is useable but there are better options ie the JS RGB>VGA BOX
  3. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I looked at a spec sheet for the above and it said that the screen has a couple of RGB scarts built-in. No boards needed! Does that mean that scart quality is going to be better than through a board?
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    The only connection this screen comes with is a VGA port, everything else is extra
  5. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    What are the advantages of a HDMI capable player? Im not quite sure......?
  6. KBDVD
    KBDVD
    Aug 25, 2002
    723
    Hertfordshire
    +6
    Hi geeWcee, :hiya:
    A HDMi is a straight "Digital" connection between source and panel = NO Analogue to Digital conversion = Better PQ! :clap: ............ simple realy. (At least in theory! ;) )
    Oh, and its highly likely that the next generation High Definition disc players expected @ the end of 2005 / early 2006, (either HD DVD or Blue Ray) will reserve their "full resolution" output to their digital connectors only, (be it HDMi, DVI HDCP, SDI or some new fangled alternative) due to the copy protection advantages offered by digital connections over the old analogue ones.
    These players may still be equipped with analogue connectors, be it Component, RGB Scart or even S-Video, but High Definition signals "may" be "downconverted" from these outputs. ......... It certainly looks like this might be the :censored: case!
    So, if your buying a panel now and you think you may be interested in High Definition DVD in one flavour or another, (or even Sky's proposed HD TV service in 2006) you would be best served by looking at buying a higher resolution panel now (1366 x 768 pixels) and in addition making sure that it has digital connectivity available, if not on board, then at least by way of optional plug in digital input boards which could be bought later on.
    Hope this has helped and I've not put you to :boring: lol!
    Best Regards,
    Keith.
    Best Regards,
    Keith.
  7. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    No Keith, you answered my question perfectly well. Cheers for that mate ;-)
    Might get a HDMI board for my PW7 later then.....
