TH-42PWD7UY - Any good?
Discussion in 'Plasma TVs Forum' started by damo dela nooch, Jun 8, 2005.
  1. damo dela nooch
    damo dela nooch
    Hi y'all...
    like the look of the panasonic TH-42PWD7UY in black
    I need s-video(sky+) and component input (dvd player), needs to support prog scan through the component.
    can anyone please advise if this is a good screen and meets the criteria??
    not fussed about a tuner or sound quality.....
    Cheers?
  2. Peabo
    Peabo
    forget s-video, go for RGB scart which is tons better. Yes it supports progressive-scan and yes it's a great screen.
  3. damo dela nooch
    damo dela nooch
    Cheers Peabo.... unfortunately I'm stuck with the s-video as that cable is already chased into my living room wall (courtesy of some advice from Richer Sounds)... is s-video really that bad for sky+??
    And it does support prog scan through the component inputs??.. sorry to labour this point but I had to return a tv today after finding out I'd made a mistake with this.... if so I think I may have found my screen!!
    Thanks again mate!
