TH-42PWD7BS with 2 speakers...
Discussion in 'Plasma TVs Forum' started by bigval, Jan 24, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    I really want this screen. What solution is there for using 2 speakers only?
    Dont want to spend over £250 for the panasonic speakers if I can get an amp setup for less....
    Dont want surround as the Mrs will not have speakers on walls etc. Room is not set well for 5.1
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well any stero pair can be driven by panels internal AMP........depends on look and placement......
  3. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    So this panel has an internal amp?
    So all I would need is th panel, various connections and a decent speaker set?
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes indeed. The amp is 10wpc, and will drive some basic but decent stereo speakers from the likes of Richer sounds no problem. It has chunky spring clips to connect with, and a volume control on the remote. simple. BTW have you considered architectural speakers? ie built in to walls or ceiling? There's a surround solution to every room, it's less fussy than stereo, at least for basic systems. Or else show her www.anthonygallo.co.uk and see what she thinks.
  5. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    How do the speakers connect to the panel?
    What is the connector like?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    See above
  7. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    Whoops. I think I am getting a big screen cos I am soooo blind.
    Are the spring clips like the ones on back of most stereos where you put the bare speaker wire in?
    I could move my stereo over to near the screen. It should be a nice match.
    Will probably do me til I get more money.
    that is if the springs are like that.
    If I cant get it solved I am going for the PX11 tomorrow.
  8. RichardHannan
    RichardHannan
    Yes they are.... and my screen came with 2x 8" (approx) speaker wire !!
    FYI the Panny screen drives my Sony home cinema speakers no probs.
  9. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    Decision made then I think.
    Will use my hifi speakers til I either get another set or get the panny speakers.
    thanks for all the help fellas
  10. Clexane
    Clexane
    There is a deal going for the PW7 with Toshiba home cinema SD44 with the component/svideo/composite board built in and wall bracket for £1800.
    then you dont have to worry about the speakers.
    Hard to find but ilgs and ebuyers are running it.
