TH-42PWD7BS does it have in built scart?
Discussion in 'Plasma TVs Forum' started by bigval, Jan 25, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    1,018
    48
    +27
    Want to run sky,dvd and console thru my screen when I get round to ordering.
    I am not buying an amp at the moment as funds are tight. Will get one next month.
    So was wondering if it has a built in scart or I have to buy the terminal board too......?
    The package I am getting has 2 component inputs so I believe...what are the right cables to use from sky+ to component?
    And are there cheaper versions that £60? I know you get what you pay for but at the mo I just want to be basic til I get the cash together for more power.
    Any help is appreciated.
    I have turned away from the LGPX11 now because of the inconsistancy of opinions on lip sync and PQ.
  2. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    The only interface as standard on the Panny is the VGA 15-pin socket
    so anything else is an additional slot-card...
  3. d0mj4y
    d0mj4y
    Dec 25, 2004
    130
    Norwich
    Stevie, in response to your signature.
    What about the decision to use VHS over Betamax. I'd say that was a step backwards. :)
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the dual component board allows one component connection...if your dvd is a recorder and has component out an option is to run sky via the recorder and component from the recorder to the component board on the panny. I believe that if you get the scart board it has just one scart socket so you may need a scart switch if component is not an option. Depending on which amp you get will change your connection options.
