TH-42PWD7BS. Changed my mind again and need a little help
Discussion in 'Plasma TVs' started by bigval, Jan 23, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    968
    +18
    http://www.av-sales.co.uk/plasma/html/panasonic_th-42pwd7bk.html
    Looking at gettin the silver one with stand.
    1. what is the free dual slot component terminal board?
    2. I use sky+,dvd,xbox and ps2. Would that component board be enough? Or do I need a scart board?
    This is the main thing I cant understand when trying to buy a plasma.
    3. Would I get a much better result with this screen than the LG PX11?
    4. My room is not suitable for 5.1 what would you guys recommend instead?
    5. How fast is AV-Sales delivery times?
    Thanks for all the help guys. I might get there soon. Better safe than sorry tho :)
  2. bigval
    bigval
    Dec 30, 2004
    968
    +18
    If nobody can answer the questions how about telling me the best way to connect sky+
  3. albertz
    albertz
    Sep 19, 2002
    346
    Newcastle upon Tyne
    +21
    why is your room not suitable for 5.1?
  4. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    scart cable from Sky+ to RGB - VGA converter then VGA lead to plasma VGA port (free)
    component (3 RCA) cable for DVD player to component board
    probably need a scart switcher to connect your other equipment
    cheers tam
  5. bigval
    bigval
    Dec 30, 2004
    968
    +18
    @albertz:- Room is a daft shape. Has 2 doors so furniture has to go in a certain way. The TV equipment goes in one corner. And the couch has to go along the back wall with a door on either side of it. Just cant see how I can get the speakers in place :(
    @tamthetim:- So the board I get free with the screen will do for the sky+?
    And will I get the vga lead with the board or do I buy seperate? Want to get everything in one go.
    Also is a scart switcher what you connect multiple scarts to and select the one you want to feed to screen? If so I already have that.
    And can anyone confirm this is a much better buy than the PX11?
    And what is the difference between TH-42PW7B and TH-42PWD7BS?
    Is the S for Silver?
    thanks for all the help guys it is really appreciated :)
  6. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    bigval
    if you're not buying an amp and speakers (can't you wall mount them behind the couch)..........................are you ging to buy the panny speakers.............made for the panel.
    remember its just a display panel you are buying..............it has 3 slots for boards to connect equipment to.....scart........component.....composite etc.
    component doesn't carry sound.................correct me if i'm wrong somebody.
    if you're going down that road......you might be better getting a free scart board and connect everthing through the switcher you already have, even sky.
    the VGA port in standard on all screens.............but don't think this carries sound either.............but the scarts do..................the majority of people who buy thses panel would have an amp.................or a one box solution sony DAV etc
    think the D means it the business side of panny's panel - probably confused you even more!
  7. bigval
    bigval
    Dec 30, 2004
    968
    +18
    Can you give me a link to a good amp so I can see what I need?
    I will need some sort of speakers as I was aware that the panel had no sound.
    Would I be able to feed it thru some hi-fi equipment?
  8. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    Link for an amp........Yamahas are good also
    http://www.av-sales.com/html/denon_avr-1905.html
    Depends on hifi.................connections etc.
  9. bigval
    bigval
    Dec 30, 2004
    968
    +18
    http://www.av-sales.com/html/yamaha_rx-v350.html
    would that do the same job? Dont want to spend too much on this yet.
    Also am I right in thinking I can get any speakers I want and connect to the amp?
    If I went the way of getting a new dvd with 5.1 then I guess I cant hear sky thru it.
    I am really struggling here. Not really well up on it.
  10. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
  11. Sparkster101
    Sparkster101
    Jan 17, 2005
    65
    11
    +4
    Assuming you get the component board (best quality) then the 5.1 system will need compenent outputs.
    DVD System (with speakers) > Plasma = using compenent
    You can then link:
    Sky Box (using RGB to VGA) > Plamas = Using VGA Port. (£126 ish)
    [​IMG]
    Sound for SKY would have to be channelld into the DVD system, probably via some good quality phono cables.
    Any other connections would have to be via scart and use a Multi Scart Controller (£56ish) plugged into the RGB to VGA connector. Sound again would have to linked from your Xbox (dotn know what connectors that has) to the DVD player probably by phono cables again (assuming your DVD player has enough INs).
    [​IMG]
    Hope this helps, shows the need to consider your DVD Cinema Box carefully.
  12. albertz
    albertz
    Sep 19, 2002
    346
    Newcastle upon Tyne
    +21
    you could go down the home cinema in a box route, with a small room this would probably be best, its best to find one that outputs via rgb scart, i have a pioneer ns-dv88 ( via s-video ), not the best connection, but it will route sound through it, and the speaker cables are easily pushed down behind carpet and floor strips ( thats what i did ) this would be far cheaper than a dedicated set up, some manufacturers even do wireless rear speakers ( JVC ) but i dont know if these are any good,
    it would certainly be a shame to lose out on 5.1, even in a small odd shaped room the difference is huge.
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
