TH-42PWD6BX and speakers
Discussion in 'Plasma TVs Forum' started by docfeelgood, Nov 5, 2004.
  1. docfeelgood
    docfeelgood
    Sep 9, 2003
    237
    Looking at this plasma to replace my TV (PANA TX36PF10 - which I'm selling).
    I can see a lot of posts here regarding this plasma and connections.
    My questions are quick and simple.
    1. I would prefer to have the speakers attached to the screen (the plasma will be sitting on a cabinet of some sort). Are the speakers TY-SP42P5W any good? as they are rather pricey.
    2. Do these speakers need a separate amp? .. or can you just plug your audio sources speakers via the plasma and forget about a separate amp/receiver.
    3. Once I've bought the panel, boards, switching requirements, cables, cabinet etc...... would I be better off buying a viera as a replacement TV?
    best regards
    Doc
  2. dannyboy23
    dannyboy23
    There is a small amp in the Panny6 (so I believe) so you can run these speakers without the need for an amp.
    I have heard the speakers are ok. The reason I have gone for them is pretty simple, another seperate speakers would have looked bad in my room...this was my only real choice!
    D
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Veira is designed to replace TV's a panel is more flexible (complex) and really suited to being a display in a HC system not a telly. so you may be better off with the Veira
