We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Th-42pv500
Discussion in 'Plasma TVs Forum' started by khizman, Oct 30, 2005.
  1. khizman
    khizman
    Apr 8, 2005
    78
    where is the cheapest place to buy this set?
    I ahve been told that is the best plasma screen out.
    is that true? :D
  2. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,709
    137
    Middle Earth
    +1,110
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    If you have a look at this thread it should supply some answers. Also do a search for PV500 and you'll find lots of useful answers.
    As for your statement, it is regarded on these forums to be a very good plasma TV. There are other ones, such as the Pioneer 436XDE which is another cracker of a TV. However, depending on your budget, you may also consider the plasma panels instead of the TV's. Such as Panasonic PWD8/PHD8 to also consider. Once again, do a search in this forum for the model numbers and you'll find loads on useful info.
    What's your budget and other kit you have to help us in helping you choose?
    Andy
  4. khizman
    khizman
    Apr 8, 2005
    78
    i dont need any other kit, just a stand for it too.
    absolute max is 2k for it and I would like a long warranty too.
    I see john lewis have 5 year warranties.
