Th-42pv500 OR PDP435XDE
Discussion in 'Plasma TVs' started by dapex, Jun 6, 2005.
  1. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    hello folks, MY RPTV started playing up and so I decided that as soon as it goes I will get me anice new plasma, I have seen the threads about the panny Th-42pv500 and i do like the look of it, but then i noticed that the Pioneer PDP435XDE isnt really that much more expensive, but I dont really know if it Pioneer is any better or not, the specs look pretty much the same to me (screen res etc)
    Any thoughts on how the pioneer stands against the cheaper Panny?
  2. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    you really need to get a good av company and demo them both, I've just set up my xde and love it, but you'll find that you'll gets lots more posts telling you to go panny :rolleyes:
