TH-42PH9 Set Up
Discussion in 'Plasma TVs Forum' started by Marcus D, Jan 4, 2007.
  1. Marcus D
    Marcus D
    Mar 2, 2004
    111
    Oxford(ish)
    +3
    Just taken delivery from the powerbuy and need some advice as to the best settings for the first 200 hours ? Seen few threads but does anyone have them all listed they could cut and paste????
    Just fitted to wall and want to set it up 1st thing in the morn :) :) :)
    Marcus
  2. rwttm001
    rwttm001
    Sep 25, 2006
    1,811
    Leeds
    +118
    Morning Marcus
    First thing, make sure you bung it into Cinema mode and reduce Contrast and brightness as low as you comfortably can.
    Consensus is to run it in at these reduced settings for c200 hours (in the SD service menu, hold down the Volume down button on the panel and hit the Status button on the remote 3 times to get hours so far), then bring them up to desired levels.
    Finally make sure you're doing the panel justice in terms of cabling, can make a big difference to the PQ!
