TH-37PWD8UK & Non-Panny Speakers
Discussion in 'Plasma TVs' started by jfalek, Aug 7, 2005.
  1. jfalek
    jfalek
    I am interested in getting the TH-37PWD8UK and have limited wall space (this is for a bedroom). While I may connect it to my reciever, I will also just want to use it "on-the-fly" and be able to just turn it on for some non-movie situations.
    The "optional" panasonic speakers attach directly to the sides of the unit which adds another 8 inches to the size which makes it too large for the space. Will this unit take non-panny speakers? It looks like I could add any set of speakers (albeit small) directly to the TV and place them at somewhere which doesn't add width to the unit.
    My other option is to wait for the TH-37PD50U, whenever it actually comes out in the next few months.
    All insights and views would be appreciated. Thanks -
    James
  2. BruZZi
    BruZZi
    May 9, 2004
    28
    Yes, you can use any other speaker (6-8 ohms) with the TH-37PWD8UK.
    The built-in in amplifier is only 8w per channel so don't expect much.
    Don't know which Country you are from but...
    There will be NO 37" PD50U Model for the US Market.
